Application Compatibility Toolkit/Qfixapp
28 Dec 2003
Scotland / Norfolk
Hi,
Basically I am trying to install Championship Manager 01/02 on my machine. It is running XP home. The previous pc I used the game on was running win98 and I never had any issues with it but whenever I try to start a new game on this one CM gives me an "out of memory" error. Apparently this is quite a common problem when using it on XP and all I need to do is run "qfixapp.exe" which will fix this error. Apparently it comes with the windows application compatabiliy toolkit. However I have downloaded this and cannot figure it out at all. It does not appear to contain this qfixapp.exe that I need to run. Does anyone know where on earth I can find it. I have looked on the MS website aswell as the CM website and google, with no luck.
Cheers.
