Application crashing
9 Dec 2007
I am an absolute novice with Macs, and am having a pain getting WW2OL working correctly on one, although Ive had it running it before without issue. Although this probably isnt the best place to ask, these forums are far more active than the WW2OL support ones.
Whenever I launch the game the screen adjusts resolution and goes blue. It then closes and goes back to desktop without any error or prompt.
I have tried reinstalling to no avail, although Im not actually sure Im uninstalling the game right. I am simply dragging the icon from the Applications folder in to the trash, as I read on a website, is that correct? What else could I try? I have also tried all the available resolutions in the game settings with no luck.
