Hi all,
I have 2 folders that are identical (for backup purposes), is there a software that i can run that will look at both folders and if there are any differences then mirror those differences, for instance if 1 of the folders has some new files then this application copies them across to the other folder so both folders are then exactly the same?
Thanks
Thanks
