This seems like a stupid question but I wanted to make sure before I modify my system.
Basically, I'm going to install an SSD drive alongside my current HDD. The OS will be on the SSD but some of the applications that require lots of space (games/steam for example) I'll want to install on the HDD. Subtracting the space occupied by games and large files on my current HDD brings everything down to less than 100GB which means a 120GB-200GB SSD should be adequate for my needs.
Will it simply be that when I install the applications I tell them to install on D: (HHD) and that will be that? Of course some components will still be installed on the SSD with the OS but the bulk of it will be on the HDD. I was just thinking of creating a folder D:\Apps or whatever and use that. Seems like a silly question but I've never set it up like this or know if it will work OK.
EDIT: Forgot to mention that I use Windows 7.
