Hi Guys
My new build is complete and I've booted up into bios screen. I'm running an i7 920 at stock speed.The idle CPU temp is reported in the bios hw-monitor as 42 degrees.
The thermal paste used is Artic Cooling MX-3.
The HSF combo is a Prolimatech Megahalems with an Akasa Apache Super Silent 120mm fan @ 1400rpm. The fan is set to push upwards through the heatsink. I wasn't sure on this, what's the best set up for single fan, push or pull?
Anyway, the temperature is a little higher than I would have expected without overclocking. Could I have applied too much thermal paste?
I put quite a thick line (about as thick as the MX-3 nib) straight down the centre and then two blobs on either side. Rather than spreading the paste I just positioned the heatsink on top and fastened it on.
Thanks for any advice.
