Applying for 2 Positions in the Same Company?
19 Nov 2004
Wokingham
I've seen 2 jobs both with the same company. Should I combine my cover letter to apply for both jobs or create 2 separate applications?
The jobs are very different; 1 is something I already do and the other has a lot of elements that I've plenty of experience in. Any advice would be great :)
I wouldn't apply to both since that sends a message that you don't know what you want.
If the company is small enough where you could conceive that applications for both roles pass across the same desk then I would apply for the job you want to grow into and hope that if you get knocked back from it they realise that you'd be a good fit for job #1.
