Applying MX-1 Thermal Compound
17 Jan 2005
England
Hi guys,
I was just wondering what the best method of applying MX-1 Thermal Compound is?
I've used Arctic Silver before and I've always used the method where you apply a dot in the centre and then press & twist the heat-sink on top. I've never been sure if I've used the correct amount!
The MX-1 instructions say to use about 8% of the tube - how am I supposed to know what 8% is?!
Any tips or advice would be greatly appreciated.
Thanks.
Like that will be fine. Atleast then it's covering the area the core is under. I have also used the method where you spread the compound very thinly over the core or heatspreader. TBH the results are quite similar!
If the temps are good then you've done it right! ;)
gt
