Is the best method to apply Thermal Compound to GPU like that for CPU - apply a blob in the centre and press down.
I ask because
(i) The CPU method doesn't cover the whole area but does do the important bit in the middle where the cores are. Is that okay for the GPU.
(ii) The CPU method involves twisting the heatsink back and forth to help spread the TIM out. But the GPU HSF has 4 mounting lugs that go through the CPU so you can't twist it
I'm using MS-3
Cheers,
Nigel
I ask because
I'm using MS-3
Cheers,
Nigel
Got MX-2 instead.
