- 11 Mar 2009
I need to re-apply thermal paste to a CPU (AMD AM3 Phenom II, Tri Core) and Heat Sink (Arctic Freezer 64 Pro).
I have bought some themral paste (Akasa AK-455 Thermal Compound), but I need to remove the remnanats of the old paste that originally came with the heat sink and got smeared on the CPU. I've heard that Isopropyl Alcohol is a good solution to sue with cotton swabs, or a cleaner like the Akasa AK-TC TIM Clean CPU & Heatsink.
Is there anything else around the house I can use to clean the CPU and Heat Sink, or should I order one of the above two solutions before attempting to re-apply the paste?
Also, I've heard that using a credit card to re-apply the paste evenly across the CPU is a good idea. Would you recommend it? Also, how do I ensure that the force from the Freezer Pro 64 won'y cause any thermal solution to seep out of the sides and into the chipset? I mean, you've got to be pretty harsh with that Freezer Pro to get it to lock in, and once it's locked, I don't think there's any way I can see the sides to be able to clean away any surplus...
Thanks for any help you can provide. (I know I'm becoming a bit of a pain on this forum
- Dave
)- Dave
) it bent about half of the pins on my CPU, which I realigned with a screwdriver. luckily everything was fine although it really does pay to be gentle and dont force anything.
