Applying thermal paste (Zalman 9700)
Isnt there anyone here with experience on Zalman thermal paste?
Yup iv used it before, i did follow there guide how to apply, one thin layer on cpu, one thin layer on cooler, by thin i mean really thin, had absolutly no issues at all.
Or alternativly u can just apply it to the cpu only, iv done it both ways and both ways work the same way, i used it at the time to try it out and thought cool u get a brush to apply it lol.
Personally id just add it to the cpu only, as thats more then enough, but if u want peice of mind, do how zalman suggest.
Thanks for the tips guys, the cooler is now installed :D.
Removed the old paste with some aftershave (works a charm!)
Applied a thin layer of thermal grease on BOTH the HSF and the CPU, turns out it wasnt overkill.
Temps:
Idle: 30-37C
Load: 45-50C
Thanks again guys
