Applying Thermal Paste
11 Apr 2007
Hi all,
I've read numerous threads about the best way to apply TIM but I just wanted to get ure opinions if u would be so kind!
I have always used a credit card and spread a very thin amount to cover the surface of the cpu but having read some threads today I'm beginning to wonder if this is the best option.
Looks like a lot of people use a thin line of paste instead.. My worry would be that it may not completely cover the surface but Artic Silver recommend this method..
What do u think?
I used to spread manually with a credit card, but on following the AS guide on their website and then later removing the sink I found that it has spread fine.
I'd agree there. Arctic recommend a method where you make a line of paste across the cores of the CPU, but I'd stick to spreading it thinly and evenly across the IHS. :)
I've been reading it depends on what cooler you're using (e.g. flat base or heatpipe Direct Touch).
Anyhow, I've always placed a rice grain sized on the cpu and then put the cooler on top and twist it several times before securing.
You use rice instead of thermal paste? Nice! ;)
What I do is this:
Tiny amount on a finger covered with clingfilm (say 1/3 rice) and apply to IHS and heatsink and rub it in...
Then apply remainder (2/3 rice) in a line to follow the cores on IHS and shove on the heatsink...
The first ensures theres a thin layer over the whole IHS and heatsink (probably superfluous but makes me happier) and might help with heat conduction (fill in the microscopic gaps) and the other is just what AS recommend (though I use OCZ freeze). I just dont think spreading the whole lot across the IHS helps since predominately the heat will come from directly above the cores...
ps3ud0 :cool:
