- 6 May 2008
Hi all, I have an old machine running windows xp pro sp3 up to date with all patches which has been running great the past month I have noticed just randomly the hard drive ticking over for no reason what so ever and when I have looked in task manager I have 2 exe files using a lot of memeory then 10 minutes later they dont the exe files am on about are wuauclt.exe and this is using 119,368k and svchost.exe and this is using 117,052k the spec of this machine is amd athlon xp 1.67ghz and 512mb ram now when those applications use a lot of power the commit charge in task manager goes from 500-600m/1248m to 1007m/1248m also just to let you know am using nod32 smart secuirty and this is up to date also and I have ran a smart scan and it has found 0 problems and have also ran malwarebytes full scan same again found 0 problems also put in the xp disc and when to run and put command in sfc / scannow I hope someone can help I hope I really dont need to reformat.
