http://www.overclockers.co.uk/showproduct.php?prodid=FG-013-SY
The Scythe Kaze Maru 140mm Case Fan is perfect for those in search of silence. At 140mm it only has to spin at a fraction of the speed of a 120mm to push the same amount of air. With 120mm sized fitting holes the Maru has the excellent feature of being compatible with almost any case that supports 120mm fans. With a price of only £8.99 +VAT the Maru is one of the most economical ways to silence your PC.
So now 140mm fan fits in a 120mm fan hole?
I think thats a bit like the pre-school Square peg - round hole problem no?
Or am I missing something obvious?
