i
i have purchased the following kit and setup the pc and all working well except the graphics card and crossfie.
Samsung Green DDR3 8GB 1600mhz
AMD A6-5400K Black Edition 3.60GHz (Socket FM2) APU with stock cooler
ASRock FM2A75M-ITX AMD A75 Chipset (Socket FM2) DDR3 Mini ITX Motherboad
OCZ 480 bigfoot ssd
450 gig WD velociraptor
corsair HX650 m psu
MSI HD 6670 2048MB GDDR3 PCI-Express Graphics Card
bitfinex prodigy case
the bios has been updated to 2.8 on the mobo and the fan on the 6670 spins. under the mobo i have selected pci-e GPU as main graphics but no signal comes out at all. from both hdmi or vga. onboard graphics runs fine.
i viewed the help files and it says to install both drivers, onboard first, then it should give you the option under the amd catalyst control to select crossfire but it doesn't.
under device manager, the 6670 is not there at all. could the card be faulty?
what settings do i need to get crossfire to work or even the GPU!
OCZ 480 bigfoot ssd
corsair HX650 m psu
