- 4 Oct 2005
- Herefordshire
Hey guys im after some advice please.
While looking around at a lot of fan controllers, I finally after a lot of recommendations on these forums bought a :
Aqua Computer Aquaero 5 XT LCD Fan-Controller
http://www.overclockers.co.uk/showproduct.php?prodid=WC-000-AB&groupid=701&catid=2331&subcat=189.
So with this in mind I would like to ask some questions to things I will be possibly doing with it(if I can) and since a fair amount of you guys use it this Is the best place to ask.
Can I connect my d5 vario pump to this controller without buying anything extra ? and retian full functionality, or do I need to buy something else ?
I am using Noiseblocker NB-eLoop Fan B12-3 - 120mm (1900rpm) to put on my 2 rads, so 8 of these fans in total. is it possible to connect 4 of these fans to each chan ? and would I need some sort of fan splitter cable ?
So in other words, on chan 1: 460 rad group
and on chan 2 :360 rad group.
then use the other 2 channels for the rest of the case fans inside my 900d ?
I have on its way a temp sensor(monsoon one) can this be connected directly to the device ?.
Is there anywhere where I can read on the software setup ? perhaps guides ect ?.
I know its a lot of questions only I am new to this.
Thank you in advance.
