- 22 Sep 2020
hi all what are the diffs from Aqua Computer Dr. Drop Professional Pressure Tester Including Air Pump Vs Aqua Computer Dr. Drop Pressure Tester Including Air Pump?
any you use that are good?Might just be
Ones made of plastic
And ones made of aluminium
Though I would go for a leak tester that has
A hose personally
Doesn't look like those have one
As not always going to be easy to directly connect
To a port you want to test
i just sent mine one of them back to ek as it keep leaking air on tester sideI bought and use one of these, seems fine for £24 and makes leak testing really quick!
EK Water Blocks EK-Loop Leak Tester Flex
Order EK Water Blocks EK-Loop Leak Tester Flex now online and benefit from fast delivery.www.overclockers.co.uk
