Aquacomputer Aquasuite
10 Dec 2020
I have just started using this software and whilst I have been able to do the basics out of the box, there is clearly a lot more in there. For example I want a "live" chart of temperatures so that I can tune my fan profiles but I could't work out how to create one. So I copied and pasted one from the High Flow Next overview page onto my custom page. Although that works I feel frustrated that I should be able to create these things from scratch. Does anyone have links to resources that might help me to learn how?
Most AC component manuals cover detailed use of Aquasuite features. Download from the Handbuche section on their website for the latest versions.
I imagine it will be something involving the set-up of Log Data Chart... though you'll first have to set Aquasuite up to log that data (under Data Log tab) from your chosen source(s) in the first place, before displaying the chart on the Overview page.
If you want to get really fancy, the Playground lets you create all manner of complicated algorithms to average out several different data sources and stuff... which again could be displayed in your chart.
