Aquacomputer Controllers and PWM Pumps
7 Oct 2015
Hey guys,
I want to control my fans and pump on a fan controller and know that AC have a couple which can do this without using the Aquaero controller.. The Octo and the Quadro.
Does anyone know if the Splitty9 or the Splitty9 Active can handle both PWM fans and a PWM DDC/D5, or are they specifically for fans only?
Are there any other controllers which are able to handle both?
Thanks
Haven't tried, however the Octo/Quadro cant be used as an Aquabus master device - only a slave.
I'd assume if you added a splittly9 it could only be used as a dumb fan extender - all the same speed.
You can add the PWM connection from the pump (example an EK) to one of the other 8 ports on the Octo though.
