Permabanned
- 11 May 2011
- glasgow
Little bit confused at the moment got my aquaero 5 lt all connected up and in aquasuite fan 3 is reading 11.6v and 0rpm yet the fan is still spinning away, checked in the controller section and the fan is set on a constant value its set to max, can set the rpm range in the advanced settings in the fans section and you can hear the fan slowing down any ideas as to why its not showing on the aquasuite software currently running aquasuite 2012 beta 13
