- 10 Jun 2017
I know the 6 is newer, but what are the differences? What are the main points for going for the 6 over the 5?
Yes that would still work. You'd just bring the PWM control signal out of the Aquaero on its own, same as how it's been working for you so far. But then what function is the Aquaero really performing for you?Oh ok, so I have 8 pwm fans. At the moment I have all 8 pwm fans on a pwm splitter with a power adapter so they don’t lose power. If I connected the splitter to the 1 pwm port on the Aquaero 5 would this be sufficient? Or would the auaero 6 be better?
I don't think having all fans controlled by single signal is best idea.Oh ok, so I have 8 pwm fans. At the moment I have all 8 pwm fans on a pwm splitter with a power adapter so they don’t lose power. If I connected the splitter to the 1 pwm port on the Aquaero 5 would this be sufficient? Or would the auaero 6 be better?
