- 6 Jan 2013
- Rollergirl
I've got a slightly unconventional set up, although this is OcUK so probably not that unconventional
https://forums.overclockers.co.uk/threads/external-rad-at-window.18794221/
I'm currently controlling everything via my Gene VIII which gets the water temperature from a XSPC inline sensor. However, I'd like to pick up an Aquaero 6LT for a bit more control over things. The slight issue I have is that the external rad fans aren't reachable with a normal fan cable.
The question I'm really asking is how many extension cables would it be OK to use? The external radiator is 480mm so that's 4*120mm fans. In order to get from the PC to the external rad, I need to link 3*4-pin fan extension cables. I would then have to use splitters to each fan. Is that feasible? The only alternative would be to run 3*4-pin fan extension cables from each channel, but then I wouldn't be able to control anything else (internal fans).
Is volts drop an issue when daisy chaining fans? Does anyone know the maximum daisy chain I can do on each channel?
