Hi, I'm sorry if this has been asked before, but I have a build with 5 ARGB fans, CPU, GPU water blocks and pump/res also ARGB controlled.
I would like a controller hub to control the RGB and fan speed, the only one I can find is the EK connect which gets very bad reviews, which leads me to the Aquaero controllers but they only seem to support Corsair or Nzxt fans, I I’m reading it right, which I don’t have.
It’s going into a new build using the hardware in my sig.
Would I be right in thinking the only way I can do this, would be to use separate ARGB and PWM fan controller and let the motherboard software control them, or is there another way to do this?
