Aquamark errors
12 Jan 2006
Anyone seen this before?
If so any ideas how to fix it?
I have searched around and there are posts on general errors, but my system is a fresh install and it has no problems running any other games
Thanks in advance
I used to get this problem all the time, and could find very few details about it. There is a download available (can't find link sry, google) which is a replacement .dll and fixes the issue.
The file in question is direcpll.dll, and I've also heard rumours that you can replace it with a copy of the file from 3DMark 03/05/06 - not tried myself tho.
Hope that helps.
Emailed you a copy of the newer dll file, hopefully you should now be able to run AM properly :D AM crashes as you gfx card is too new for it, it is afterall an old benchmark now though i have to say i still use it as it is so quick to run you can see the results of your tweaking in a couple of mins not like the 3dmark stuff which takes ages in comparison.
thanks a lot mate :d
i owe you a pint ^^
