- 17 Dec 2004
- Crawley, WEST SUSSEX
Hi,
Ok I was going to drill and tap a aquatube so i could fit 1/2" tubing but this will void the warranty which i am not keen on. So I can get a connector thats converts 1/8" thread to 1/4" and then get a 1/4" to 1/2" barb, but this will cause a constriction in the system. So on another fourm someone suggested this:
"Why not use your res as an acess point to a T-line? It will still hold water and make bleeding air easier"
I am not quite sure what they mean, does it mean the following:
So I have the Aquatube either mounted vertically or horizontally in the top of my Lian Li v2000 and the pump is going to be at the bottom in a 3.5" bay. So from what you have said i basically attach a t-line directly to the Aquatube and then tubing from the tline to the pump --> Rad ---> CPU ---> GPU ---> Chipset (not sure if i am having this yet) ---> t-line is that correct??
Would the aquatube still cause a restriction if i did this?
