Drazic said:AquaXtreme 50Z-DC12 Inline Pump 1/2" Barbed Fittings
How good are these?? They now the pump to have in your system??
Single 120mm radiator: First choice: Swiftech MCP600 or AquaXtreme 50Z. Silence Choice: Eheim 1048
Dual 120mm radiator: First choice: Iwaki MD-20RZ, Second choice MCP600. Silence Choice: Eheim 1048 or 1250
Larger radiators: Iwaki MD-20RZ all the way, with the MCP600 as a good second option.
Performance: Iwaki MD-20RZ
Jack-of-all-trades: Swiftech MCP600/AquaXtreme 50Z
Silence focused: Eheim 1048
Running parallel isn't really great. Basically, you will have the pumps working partially against each other at the 'Y' - not much, but partially. Secondly, unless they both have a reservoir before their inlets (in between the Y and their inlet), then they will also fight for water. This is actually quite inefficient. Series is best for water setups as the pressure in the water will be doubled. Think a 1.5v battery, and then you add another one to make 3V. Each battery is a 'pump' and two will provide more pump pressure.Drazic said:Up i got my pumps outlet to inlet, thats how they are right now. Stil lwandering what it be like both outlet to a Y piece then to a singluar, same for the inlet to each
Drazic said:Been through thios, 478 is a no no on both, phase kills em as they not hot enough and water chiller might as well go phase.
