Anyone know the connector AquaComputer uses? Specifically the mini on their Flow Sensor to OCTO/Vision 53212 cable.
I need to make up a couple for a super budget build, and I don't fancy paying a 100-200% markup from UK e-tailers, for something in going to cut apart anyway.
I guess I'll need the crimps too, unless they do one with solder terminals? My guess is its an off-the-shelf Molex, but they're so numerous, and I can't afford to buy a bunch from RS, hoping I'll stumble upon the correct one
Any help really appreciated!
