Hi all,
I have a LG OLED TV leveraging ARC into my AV/Receiver (Yamaha RXV383) which also has my Sky Q plugged in. The Sky Remote is configured to send commands to my TV. I'm not sure if this is normal or not, but I experience some odd behaviour - hoping someone can clarify.
1. I have to turn off my devices in a specific order - notably the Sky Q Box first, then the TV in quick succession. If I don't, then the Sky Q box will turn back on my TV.
2. I have to turn on my devices in a specific order.
Currently if I turn on my Sky Q box, it will wake up the receiver, then the TV. If I do it another way, then when I try and adjust the volume using my Sky remote it won't work, bringing up a grey circle with a line through it on my TV. The only way I can seem to rectify this is to completely power down everything and bring it back up.
Is this normal? Should I be doing something different?
Thanks,
David
Thanks,
David
