ARC for dummies
Caporegime
28 Oct 2003
Chestershire
Can someone explain how you use Audio Return Channel on new TVs, please?
Do you plug your soundbar into the HDMI with ARC connector on the TV and then your devices like PC/console into the soundbar? Or do they still get plugged into the TV in other HDMI ports and the TV magically splits video into one port and sound into another?
Yes, ARC works in both directions. Once you've connected your soundbar to the HDMI with ARC, you can plug other things into either the TV (sends the sound to the soundbar) or the soundbar (sends video to the TV).
I have a soundbar with arc which I wanted to plug into my arc enabled hdmi port, problem is, all 3 of my hdmi ports have devices connected that are 4k, my soundbar doesn't mention what it is capable of passing through with the hdmi in port, will it need to be specifically capable of this or is arc just a simple passthrough? I was assuming it would only work upto 1080p and not support hdcp required for 4k, would I be right in this assumption?
