ARC from LG TV to Onkyo Amp cutting out due to light switches etc
15 Nov 2003
Marlow
Randomly when using ARC to pass sound from my LG TV to my Onkyo Amp I get short audio cut out. eg: 1 second or so... I can now reproduced this at will by turn light switches on/off. 50% of the time I'll get an audio cut out. I suspect other devices coming on/off might also be causing it too?
So clearly audio interference seems to be upsetting the TV/AMP. Note: I've never had any other audio cut outs other than via this connection (ARC).
Any suggestions?
Can I buy some sort of filter to maybe clear up the mains power to the TV/AMP?
If I use optical instead of ARC will I be losing anything sound wise (eg: From Plex's audio to the Amp)? - I have a 5.1 speaker setup on the Onkyo
This is an LG OLED 55E7 to an Onkyo TX-NR646.
