Arc Midi - Fan Filter Replacement
10 Aug 2011
*Sorry wrong subforum!
Hi folks,
I'm looking for a filter kit for the Arc Midi Tower case. The top and bottom filters are bust after a molex to sata adaptor failed and set them on fire. Fortunately nothing else was damaged.
Are there any other options? Can't even see a filter replacement kit on the Fractal site.
Cheers
As you've realised, this should really be in the cases sub-forum.
Might be worth contacting Fractal Design and seeing if they can send you a replacement filter.
