ARC problems with a Samsung UE55K7000 and the Yamaha RX-V381
8 Jan 2013
Grenoble, France
Hi all,
I am trying to setup my new UE55K7000 TV with my new AV RX-V381 reciever but getting no signal on the HDMI inputs when ARC is setup on the AV Receiver. However, I can watch the direct output from the Smart TV like Netflix or Youtube. If I change the source for HDMI 1, 2 or 3, the TV doesn't find the source. However, if I turn ARC off on the Yamaha receiver, I can see the HDMI inputs but then I can't hear any sound on Youtube.
So I have four HDMI inputs all connected to the HDMI on the AV receiver. HDMI 1 setup with Humax box, HDMI 2 setup with Playstation 3, HDMI 3 with Orange French TV box, and HDMI 4 with the Steam Link.
The Receiver is connected to the TV through the receiver HDMI output, the One Connect box on the 4th HDMI which is marked for ARC.
Any thoughts on why I can't find the sources when ARC is enabled? I guess I'm missing a setting on a menu, but I can't see it.
Cheers
With my system i select arc on the av amp (set to av 2 on your amp) then on the tv i have to change my speaker settings from the tv speakers to home cinema it then turns arc on so if i use the youtube app say i get sound. It can be a bit flaky though with the arc handshake.
When you say you can't find the sources is that on the tv or the amp?
Have you turned hdmi control to on?
Arc info on page 81 of the manual.
Swop the TV to the 4th HDMI which is marked for ARC,put the One box somewhere else.
