- 12 May 2005
Hey,
Basically I'm considering buying a stick for a few reasons.
First is I can't use one! I can do the basic motions, (like fireballs and DP) but am far from fluid like I am on the pad.
Second, I've heard that some things are not possible to do on pad (which, I am perfectly comfortable with).
Now I've always been a pad player, in tekken I was able to EWGF, Light Dash and all the good stuff with a PS pad, but now I'm considering trying out a stick.
I've a few options, the first is to buy a stick, second is to try and make my own, but - in reality, I'm not sure I want the "make a stick" project because I don't have much time, and I also don't even know if I'll use it a huge amount yet.
So I guess that leaves me with buying a stick. I've got a PS3 and 360, but will likely play my games on PS3 (SSF4 when it's released, as I've given up tekken) so I was considering buying the Street Fighter 4 arcade stick (the white one, I can't check the name as I'm at work, but it's the one down from the tournament stick.
Is this stick worth it, or better to buy the more expensive one, or better to just make my own, or is playing on pad fine? I can do everything fine, and I'm not planning to go to tournaments, just for fun, but wanted to learn to use a stick for myself more than anything.
Lastly, sorry for the length post!
