hi,
Been doing a little research on a decent arcade stick, mainly for my PS3, but if i can get it to work on the PC, then all the better AND this may also influence my decision on which one to buy.. So here i am in the PC forum....
The way I see it, I have three choices.
1.\ Hori Real Arcade Pro 3
2.\ Madcatz Arcade Fight Stick and upgrade with Sanwa stick and buttons
3.\ Hori Fighting Stick 3
Which of these will work on the PC ? I've read that the HRAP 3 will work on a PC, but no-one has really confirmed it, from what Ive been reading, and on the other two? Well not much info at all... I'm guessing no, but ya never know !
If the regular Fight Stick 3 works on PC and PS3, then i could be tempted to go cheap and just get that, since it's readily available and half the price of the other two...
But seeing that the HRAP3 is the only one that says PS3/PC then i'd like to get that, since it has the quality I'm after and after upgrading the Mad-Catz, the same price.. Seen that it will be in stock on the 15th June.... but i believe it when i see it...
Is the Hori Real Arcade Pro 3, the only stick that'll work on my pc?
Running Vista Ultimate 32-bit... (do have dual boot XP SP3 if it doesn't work on Vista) Spec in sig.
