Hey guys, thought i'd try Arch out since I've been using Mint for the last year or so and really loving it, having some problems while trying to follow the Arch beginner guide though.
Trying to set up a dual boot with Windows 7 so have selected Manually Partition Hardrives, made:
sda2 20gb, type 83 to hold the root folder,
sda3 4gb, type 82 to hold the swap
sda4 16gb, type 83 to hold home
Then proceeded to Manually configure block devices...
For SDA2 - Clicked yes to recreate the filesystem, and made it ext3 and made the mountpoint root,
For sda3 - clicked yes to recreate the filesystem, made it swap
For sda4 - Clicked yes to recreate the filesystem, made it ext3 and made the mounpoint home.
When I tried to continue it then told me "Error mounting /dev/sda2 on /mnt/" and then the same for sda4.
Quite confused as I've followed the beginner guide pretty much I think.
Thanks for reading!
Thanks for reading!
