Hi,
I have some data that I need to archive off direct to DVD.
I'm looking for a way/software to do this. It must split my data in order to span across DVD's. The archive cannot depend on a program specific file extension. e.g Nero BackupITup or Acronis True Image etc. The reason being that decades down the line this software probably won't be around anymore for me to restore.
So the suitable format I'm thinking of is TAR, or probably zip. No compression is wanted since data is already in a compressed format. Data will be spanned across multiple DVD's, and if 1 DVD fails then it must not affect the data on other DVD's.
The sticking point is I need to burn the data direct to DVD. All the software I've seen so far is either proprietary format or needs more disk space to write the split files to disk first, which I then have to burn to DVD. I don't have disk space to do this.
Anything out there, or you guys have used before?
Kind Regards.
Kind Regards.
