Been considering a couple of Arctic Accelero Xtreme IVs for my cards - was planning a full custom loop but I may just do that on the CPU or stick with an AIO. Only problem would be if they’re not compatible with a future card I buy as obviously it isn’t worth spending £50 I can’t get back on a 780 ti at this point.
Anyway the older models come with heatsinks to stick directly onto the VRMs and RAM chips directly under the cooler with the fans blowing on them, the newer ones come with a rear mounted cooler that contacts the back of the PCB where the VRMs etc are mounted
Anyone got any experience with these and how are your VRM temps? I’m very sceptical of the ability to be able to cool them effectively through the PCB with nothing directly contacting the front of the chip (although they’d still have the fans blowing on them).
