Arctic Cooler 64 & no IHS
12 May 2005
Stoke, UK
I have had a search around the forum but it hasn't help.
Will it be ok for me to run an Arctic Cooler on a Opteron with no IHS?
Thanks
anyone?, sorry to be a pain but ordering stuff now, want to get it shipped tommorrow, i just got myself a Biostar TForce 6100 and need a cooler but my opteron got no IHS.
Personally i dont think it will be ok. Good coolers for a IHS'less cpu are ones that screw down mainly like the Thermaltake Big typhoon and the akasa evo series
If the Arctic Cooler attaches to the retention bracket with a clip mechanism then it wont work. As above I would advise getting a screw down one like my Akasa Evo 33 ;)
Any help choosing one, I heard the Zalman are good?
It's an opteron im looking to overclock, so would like a decent one.
Thanks
Zalman FS-C77 Fatal1ty CPU Cooler - Retail (HS-018-ZA)
Is that Zalman a screw down?
This is for an ATX system that will likly be moved, is screw down fan a good idea in a system thats gonna get moved, or should i reattach the ihs?
I would recommend the TT BT as well, though it might not fit your motherboard, what type do you have?
I've had a look at that type of clipping mechanism on the Arctic Cooler and though it should make contact I doubt it does so with good pressure.
Jokester
Well, my motherboard is the Biostar mATX 6100/410.
Would it be possible just to rest the IHS on the CPU and attach a normal cooler?
If the IHS is tightly pushed to the CPU (the clips should do this) it should keep cool, am I right or am I so far off its unbelievable?
I have my board and CPU now, so im looking for a fan ASAP.
Thanks
