Hi Guys,
I'm sure this has been covered before, I tried to perfom some searches but I couldn't come up with anything that fitted my query.
I have the AC 64 Pro and a DFI SLI-D mobo. I wanted to sort out the case flow in the PC and wanted to change the orientation of the cooler so that the cooler's fan is parallel to the rear case and the front fan. At the moment, the AC is 90 degrees adjacent the the front and rear fans (I'll try and get some pics up later if it helps clarify things) and I believe the air flow isn't as efficient as it could be.
I've looked at the instructions that came with the AC for help but I couldn't find anything that could help me with changing the orientation so that the AC is in line with the case fans (front and rear).
The DFI HSF mobo mounting clip/base seems fixed to the mobo (arbeit with screws) with no option of removing them and rotating that mounting clip 90 degrees because there are no additional holes to achieve this.
If there is a way to straighten this situation out then I'd be more than happy to hear from you
Thanks in advance,
D
Thanks in advance,
D
