It's a tricky bugger to fit though.messiah khan said:Nope, it simply clips into the excisting HSF bracket.
kdd said:It's a tricky bugger to fit though.
Ah man that was a pain! Metal scraping against metal.Raikiri said:Thought it was easy, getting the stock one off wasnt though![]()
thor said:With the IHS removed off my CPU, I found the tension with the AC to be pretty much perfect. Easy enough to get on while still providing good contact.
Bigstan said:Hmm.
My 64 Pro is on my 2.4 Northwood. You're making me toy with the idea you naughty thunder God you.
Stan![]()
/Wonders where to get a razor sharp craft knife locally![]()
Raikiri said:Must be a freezer 4 then if you have it ona northwood?
Bigstan said:Note to self: Do not post in tech forums drunk.![]()
