hey guys, any users of the above HSF?
The copper base dont seem to be smooth and shiny, do u guys sand it till its smooth and shiny?
if yes, anyone can guide me on that?
would like to bring my temp down a 2-5 degrees as i feel its abit on the high side when my room is not on air-conditional
Load 50+ degrees..
Thanks..
Load 50+ degrees..
Thanks..
The fan is supposed to suck cooler air from inside the case and blow it through the heatsink fins and towards an exhaust. Your temps should drop abit if you swap it round the other way.
