Arctic cooler 9800 Pro/XT compatability
22 Dec 2004
Southampton, UK
Hmmmm ok i think i messed up, i have a ATI 9800 which i purchased 2nd hand, in device manager it shows it as a 9800XT so i went and got a ATI Silencer 3 thinking it was XT on taking the card out it appears i notice a sticker that says 9800pro 128.
So looks like i have a 9800pro which has been flashed to XT.
My dilema, will the silencer 3 fit the 9800pro, I don't want to open the blister pack to find it doesn't fit and then not be able to return it!
The difference i can see is that the silencer 1 for the 9800pro had two mounting holes whereas the XT silencer 3 has 4.
Can anyone help with the compatability?
It wont fit as far as I can tell. Arctic cooling wouldnt have made a cooler specifically for the XT otherwise
My thoughts too before it arrived, but the packaging does say 9800pro 256mb as well, but there must be a difference between the pro 128 and the 256 because all XTs are 256 i think
FYI; the later 9800 pros were actually on a XT PCB; so you may not have the wrong one.
What make of 9800 pro is it? I have one (its dead) with the XT PCB and put the arctic cooler for the pro on it and it fitted but not quite right.
I have offered my pro up vs the arctic cooling diagram and mine has the 4 mounting holes where the XT silencer has mounts and it seems to clear all the caps.
Hope this helps.
Hope this helps.
This is mine which has which has several holes:
it appears to be the Atlantis 9800pro this one
Which looks different to the picture of the one you sent me.
Would i need to remove the copper sinks as well?
Edit: After hours of googling this evening although my 9800pro is a R360 hence being flashed to XT it doesn't have the XT PCB so the Sliencer 3 wont fit it - oh well!
Yep your right
Yours doesn't have the XT PCB, so it ain't gonna fit.
Worth a check as a lot of R360 cores were in XT PCBs.
