Arctic Cooler won't come off!
  • Thread starter Thread starter HeX
  • Start date Start date
HeX
HeX
20 Jun 2004
Huddersfield, UK
Recently went SLi with a 2nd 7800GT.
My origianl 7800GT is fitted with an Arctic Cooler however its too big and when a 2nd 7800GT is fitted the fan from the Arctic Cooler hits the back of the 2nd card...
No problem I thought so I removed the 7800GT with the AC and placed the new 7800GT in the first slot, then I went to put my original card in the 2nd Slot only for the fan to touch my Audigy2!
So I was going to take off the AC for now and put the stock cooler back on until I get round to getting a couple of VF900's next week.
Only problem is the AC won't give up its grip on my 7800GT :eek:
I've unbolted it all, and where usually a bit of a push will just pop it off the mem chips this one will not budge!
It lifts off the core easily enough (like 2-3mm enough to know its not that), but the mem chips are stuck fast. I've only used the blue/gray pads that come with the kit that usually just drop off... usually...
I was litterally pulling the HSF full force (as much as I dared) but had to stop for fear the memchips were going to rip off...
Anyone got a clue how the hell I can get it off! :confused:
Rob43 said:
try twisting it,heating it up before you take it off
Rob
Can't twist it as the 4 bolt pegs are still thru the card so you only have one axis you can pull in, and thats straight up...
I'll have a go at heating it up first though...
Even a very small amount of twist can help the air get between the mem chips and the heatsink as I think thats the problem the idea is that thermal compound fills in the smallest air gaps so it forms kinda an air tight seal. There should be a small amount of twist even when it's fully clamped down.
Took 2 arctic coolers of my sli set up to go water cooled. Had the same problem. Ended up using a hobby knife to slice though the pads then peeled the remaining bit off the memory.
Daft having glue on both sides the coolers are now useless unless/until I find some more pads of equal thickness. Looked but no joy yet.
M@rt
