- 3 Jul 2005
Which one do you think will be better?
ToLearn said:well just fitted my accelero x1 and its down 4 degrees idle and and a very nice 12 degrees of loaded temps still got some more playing around to do yet oh and its very silent
this is in a lian li pc7 case at the same time i changed the 2 stock 120 mm fans for ambers cpu temp went down 2 degrees aswell but need to 7volt the ambers now as i can here them over eveything else when before it was the graphics card stock cooler
