Arctic cooling accelero, worth it?
20 Oct 2007
South Yorkshire
As the title says is it worth upgrading the cooler on my 8800GT to one of these and if so which one? I understand that i would also need some RAM heatsinks or something like that.
I put an s1 on my GT, yes it is worth it, my temps went from about 55 idle to 36 idle and 70 under load with fan @60% to 48 load, ramsinks come with the s1 but buy some thermal tape to stick em on with and a 12cm fan and strap it on with cable ties.
I was thinking of Putting a yate loon on the other end, How easy would you say it is to install out of 10 (1 being the easiest) and where could i get my hands on some decent tape?
Brilliant cooler, better than stock 1900xt and Zalman VF900. Quieter, with lower idle and load temps. Got a 12cm fan underneath.
