Hi,
As the AIO cooler has become very popular we have decided to expand the range again with the Arctic Cooling range which comes with either 4 or 6 fans depending on the cooler you choose. This cooler offers great performance and at a very competitive price.
Cooler Details:
Designed for Extreme Cooling Performance
Outstanding CPU cooling performance through Water Cooling Solution with 6 x F12 PWM PST fans, 38 mm deep radiator and efficient water pump.
Extremely Powerful yet Quiet
The Liquid Freezer 360 is not just the most powerful AIO Water Cooler in its class but also the quietest. Cooling Performance & Noise Level on Intel Core i7-5930K is 45.9C with a noise level of 30db.
Most Efficient Pump
Latest motor technology and smooth tubes offer top performance at only 2 watt power consumption.
Every Unit Performs the Same
A concentric CNC guarantees a smooth and even surface. Thus a consistent series production quality is guaranteed and every unit performs exactly the same.
Optimal Heat Dissipation
Upto Six low noise 120 mm fans mounted on opposite sides of the radiator provide a great airflow. The first two fans push air through the radiator, the second two fans pull the air through it. Controllable with PST function to adjust the fan speed based on CPU temperature.
Quiet and Powerful Fan
We fully designed the F12 fan with CFD (Computational Fluid Dynamics) software and optimized it for high airflow. From all fans tested in our air tunnel and anechoic chamber the F12 offers the highest airflow at a given noise level - by margin with 38.6CFM and a noise level of 20.5DB.
MX-4
Ready for 16 Cores and Overclocking
We pack a bag of the leading thermal compound, enough for two applications. The MX-4 guarantees to dissipating heat from your CPU in the quickest and most efficient way.
With the Liquid Freezer 240 You are! Deals with up to 300 Watts TDP - at almost complete silence.
Long Service Life
The Fluid Dynamic Bearing comes with an oil capsule that avoids lubricant leakage. Thus this bearing is as quiet as a sleeve bearing but comes with a significantly higher service life.
Arctic Cooling Liquid Freezer AIO CPU Cooler - 240mm @ £75.95 inc VAT https://www.overclockers.co.uk/arctic-cooling-liquid-freezer-aio-cpu-cooler-240mm-hs-06b-ar.html
Socket Support: Intel 1150/ 1151/ 1155/ 1156/ 2011/ 2011-3, AMD Socket:
AM2(+)/ AM3(+)/ FM1/ FM2
Only £75.95 inc VAT.
ORDER NOW
Arctic Cooling Liquid Freezer AIO CPU Cooler - 360mm @ £109.99 inc VAT https://www.overclockers.co.uk/arctic-cooling-liquid-freezer-aio-cpu-cooler-360mm-hs-06c-ar.html
Only £109.99 inc VAT.
ORDER NOW
View all AIO coolers HERE
Cooler Details:
Most Efficient Pump
MX-4
Long Service Life
ORDER NOW
ORDER NOW
