Arctic Cooling Alpine 7
26 Jun 2007
Wales
Has anyone had any experience with this it's cheap and from its customer reviews it's really good, Im going to being this with the Q6600 i know i should go with a more expensive cooler but im totally skint after the components.
Any views on this cooler again thanks guys :)
Probably no better than the stock HSF. Stretch another fiver and get the Coolermaster Hyper TX2 which should have similar performance to the Arctic Cooling Freezer 7 Pro.
Ignore the reviews, if you look there are no negative reviews on any products. Assume what you will from that. I seriously doubt that it will do any better than the stock cooler. It is made of a block of aluminium with no copper in sight. You are better off spending the extra on a Freezer 7 Pro. It can be had for as little as £12.99. If you have to go cheaper then try the Coolermaster one suggested above. It appears to be a mid-range cooler and there's a review of it over at Frostytech.
i know someone who had one on the q6600 and he said it wasn't exactly the wisest purchase he's made...
As snapshot says, spend a little bit more to get something better.
How's the monitor fairing btw snap? :)
