Arctic Cooling F12
15 Jun 2009
Looking for a fan with a black/white colour scheme for my build and came across these fans.
However, at £5 each for a PWM fan there must be a catch? The brand makes me think they're good, But the price makes me think they're rubbish.
Cant find much on google so wondering if anyone here has used these?
I have 2 of the PWM ones and Two of the normal ones and they are pretty good. Quiet and shift a decent amount of air too. £5 is a sensible price for a fan. The pricing of some fans these days is ridiculous.
Seems good then. Cant really go wrong with a £5 fan though I suppose. Just for the rear of my case to finish off the colour scheme.
Well, as soon as I get some black ram. Everything else is black and white and theres the ram which is all green.
At £5.00 each they are a bargain, particularly as they feature pwm, though mine cant be speed controlled with the akasa pwm splitter cable i have, may just daisy chain both and run from the cpu header, theyre on a par with the sharkoon silent eagle se modular fans i used to have, they were £13.00 a pop though, some fans theese days are way overpriced.
