Arctic Cooling Freezer 13
31 May 2011
noob question:
does Arctic Cooling Freezer 13 come with thermal paste already applied or do i need to order some seperatly? if so what should i get?
I don't mean to hi-jack the thread but does anyone know roughly what sorta clocks the freezer 13 is good up to to? Gotta make a choice of getting either it and an M4 SSD or the Silver Arrow and get the SSD sometime next month.
It will largely depend what voltage you require for your clock speed, you might be unlucky and have a chip thats power hungry, but typically this should allow you to hit 4.2-4.6ghz with load temp of around 75 degrees.
Had my pro revision FP13 (which is sat collecting dust) running at around 4.6ghz @ 1.3v gave me around the mid 70s under stress load and in the high 60's under gaming load.
Thanks guys, sounds like it might be worth getting it as a stop gap then picking up the SA next month, i'd be happy even with 4.4-4.5 with the arctic. Load times with my HDD are getting on my nerves so AC 13 + SSD first it is :)
