Arctic Cooling Freezer i30 and A30 coolers!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys!
More shiny products arriving in the next 7-10 days!
Get your pre-orders in now :) with a massive 320 watts of cooling performance.
Arctic Cooling Freezer i30 Intel Cooler (Socket LGA2011/1155/1156) @ £32.99 inc VAT
The Freezer i30 is an enthusiast-grade CPU cooler for the Intel LGA2011 / 1155 and 1156 sockets. With 4 direct-touch heatpipes and an ultra-quiet interchangeable 120mm PWM fan, this cooler delivers an exceptional cooling perfromance and amazing silent operation.
- 320 Watts of cooling
- 4 x direct touch heat pipes
- Fan Size: 120mm
- Fan Speed: 1350 RPM (PWM)
- Noise Level: 0.3Sone
- Dimensions: 139 x 100 x 161mm
Only £32.99 inc VAT.
ORDER NOW
Arctic Cooling Freezer A30 AMD Cooler (Socket FM1/AM3+/AM3/AM2+/AM2) @ £32.99 inc VAT
The Freezer A30 is an enthusiast-grade CPU cooler for the AMD FM1 / AM3+ / AM3 / AM2+ / AM2 sockets. With 4 direct-touch heatpipes and an ultra-quiet interchangeable 120mm PWM fan, this cooler delivers an exceptional cooling perfromance and amazing silent operation.
- Fan Size: 120mm
ORDER NOW
So the top one is a intel cooler that fits only intel sockets?
But the bottom one is also a intel cooler that fits only AMD sockets? interesting;)
I have the PDF info sheets here Ace Modder it shows i7 920 performance but doesn't say its compatible with LGA1366. Do you know if it is compat?
You have the same PDF as me then :) I noticed that myself, but waiting for a reply from A.C. hence not updating it my product info.
I spoke to them earlier and they said that it isn't compatible *yet* so maybe they are still working on the mounting kit for that socket?
