Arctic cooling replacemnet fan
18 Oct 2002
Overground, underground..
The fan on my Arctic Freezer 7 (http://www.overclockers.co.uk/showproduct.php?prodid=HS-017-AR&groupid=701&catid=57&subcat=821) has died. RMA is not an option because I had to cut away the bottom corner of the mount to fit it.
Would either of these fans be suitable for replacement (with a bit of hacking to fit)?
http://www.overclockers.co.uk/showproduct.php?prodid=FG-010-AR&groupid=701&catid=57&subcat=820
http://www.overclockers.co.uk/showproduct.php?prodid=FG-011-AR&groupid=701&catid=57&subcat=820
It's the 4pin connection that I'm unsure about.
